Re: water pump out
Don't run it any more with the water pump out or you will do damage. Hot engines can result in loss of compression, scored cylinder walls, holed pistons, and other problems all of which are far more expensive to fix than installing a new water pump. You might want to do a compression check anyway to see if compression is affected.
