How can I tell if my water pump is working using "ear muffs" with a hose on my 1973 Johnson 50? I rebuilt the water pump today and cranked it up, when the motor is running or off, a stream of water comes out the right side of the lower out drive from a weep hole. There is no upper weep hole on the motor, but there are two vertical rectangular holes coming directly out the back of the motor a few inches below the base of the motor housing. Should any water be coming out of those holes? I don't currently have a garbage can big enough to fit the motor in for a test run, so the only way I know to operate the motor is with the hose and muffs. Any ideas? I certainly don't want to burn my motor up and am not sure if it has a thermo shut off or alarm if the pump is not working. Thanks in advance for your help!
