sterling66
- May 21, 2002
- 47
Well heres the low down if you dont already know, Bought a motor,water not comming out much .<br />Took leg apart,found seal for impeller in impeller shaft,and bits of old impeller.So took it apart and cleaned everything.Put it back together,bought everything new but impeller because the fellow that had it before me had changed it?<br />And looked good.But had rammed seal into wateroutlet.Inside there is key to turn impeller on shaft?Is this the reason not having any water at pee hole.Also i blow out water jacket.This little key was round and fit on bottom.
