zippy83
- Jan 1, 2013
- 491
Hi All,
I have been noticing an issue with my water pump latley. I changed it out in the winter months and used the boat 3 times so far. Did not notice any issues out on the water. Today I wanted to turn it on because it hasn't been used in over two moths and noticed after it turns on it bareley spits any water out while using ear muffs. After I put it in gear and go up to 1500 rpm the water starts to gush out and when I go back to neutral it is a bit better but not the way it shoud be
I have there videos
After it turns on - https://www.youtube.com/watch?v=Y-iFNfvGmSY&feature=youtu.be
@ 1500 RPM - https://www.youtube.com/watch?v=3eAS119sxzo&feature=youtu.be
Back to neural after 1500 rpm - https://www.youtube.com/watch?v=CjYGrWGnYcA&feature=youtu.be
should I take it apart and take a look? I thought there might be something clogging the lines but wouldn't that be the case also when it's in gear at 1500 rpm? If I have to take it apart what should I look for? Clearly something is not right..
Thanks in advance
Zipp
I have there videos
Thanks in advance
Zipp
