Re: Water Pump Issue - Water NOT pumping out
hello again
remember, I don't know this engine, but it sounds like you are well on your way to learning about it. There shouldn't be a lot of stuff in the water pump housing, usually there are just some water pick up holes in the gear case just below where the water pump sits, they are angled forward so there is a ram effect as the motor goes forward. If the water pump is in two parts the intake comes up through the base, but if you pull out the base, often the bearings and access to the gear case is right there, so you have to be careful not to get dirt down there, and you shouldn't need to pull out the base to see whether the intake holes in the housing are plugged.
