IFish4Tuna
- May 30, 2006
- 11
Hi - I have an 8HP 1997 Honda Outboard. I'm not getting much more than a light mist out the exhaust and nothing out the dummy tube. I just changed the thermostat with a brand new one hoping that would solve it since it was all covered in salt/crap. No luck.<br /><br />So yanked it off the boat, and I went down to the lower unit where the pump is.<br /><br />I've check the impeller. The rubber is all good as are the gaskets. When I attach the garden hose connector and turn it on with the lower unit un-attached, I see the majority of the water coming out where drive shaft protrudes from the pump and a much smaller amount coming out the hole that feeds the water tube up to the engine. The house hose pressure is significantly more than I would expect from the engine running and pumping.<br /><br />I looked on the schematic on line, but didn't see any O-Ring or seal for around the drive shaft. Should there be one? Any comments from any other 1990's 8HP owners. <br /><br />The amount of water being pushed through the pump where the water tube attaches is very low. Its definitely gettting lost in the drive shaft.<br /><br />I'm sure the water quantity is not what is should be....<br /><br />Willing to take all advice...<br /><br />Ed
