I have a 1994 150 Johnson FastStrike motor (model J150GLERV) that I will be putting a new water pump kit in soon. I have never done this. I did purchase the OEM manual and have a question about installing the lower unit after I hopefully install the water pump kit. In the manual, it refers to two seals around the exhaust housing and says to replace these seals when reinstalling the lower unit. In all the posts I have read, I have never heard these seals mentioned in the water pump installation questions. Is it imperative to replace these two seals? I know if they are damaged or there is anything other obviously wrong with them, it would be a nobrainer to replace or not. I have everything I need to tackle this job except these two seals. Cost of these seals is not the issue. I just don't have a dealer close by to get them from. The nearest dealer is about 40 miles away and if I don't need to replace them I won't. Also, if anyone knows the part numbers of these two seals, I would appreciate that info. I went to the ishopmarine.com site and it looks like they would be part numbers 0320936 and 0320961, but I am only guessing. I just ordered some stuff from them and would have ordered these two seals at that time if I had read the manual in better detail before I ordered. Thanks in advance for any info you can give me.
