Water Pump Impeller
EARLS BOAT
I just installed a new impeller in my 20hp merc. i am a little uncertian that the water tube went properly into the pump housing. it had a copper tube that was a little off and it took many attempts to get the lower unit to set into place. how can i test to see if the tube is in the right place? this is a 1967 model mercury 200 20hp.
luv2b0at
Re: Water Pump Impeller
Maybe you could put on some muffs, remove the spark plugs to lessen the compression and turn it by hand to see if any water comes out of the tell tale. You may be able to see if it is partially seated that way. I just did mine and without the guide, I had a heck of a time getting things lined up properly.
EARLS BOAT
It Is A Pain In The Back Side!!! I Dont Have A Guide So Theres More Pain. Thanks For The Advice I'll Try That.
EARLS BOAT
WELL I PULLED THE PLUGS AND USED A DRILL TO TURN THE MOTOR OVER AND IT PUMPS THANK GOD BUT I REALIZED THAT I FORGOT TO PUT THE ANODE BOLT IN ITS PLACE SO NOW I NEED TO PULL THE LOWER UNIT AGAIN!!!! ITS ALWAYS SOMTHING:mad:
electricjohn
I hate when there are extra parts after a task is completed.
luv2b0at
Hey, if there are extra parts, and it still works, you didn't need them anyway.....JK
rtpassini
lol. i always have extra bolts laying around from my motorcycles....lol so far so good though!
EARLS BOAT
you said guys! those darn extra parts are always in hiding till the jods done!
fltbtmred
how do i get my lu off so i can look at my water impeller.i barely get it running but no water comes out . i have a 1979 mercury electric start long shaft i think (5509834)
