Flash Wax Man
- Jun 24, 2003
- 30
Hello,<br /><br />I just got finished installing a new Water Pump kit and wanted to know if there is a little play on the impeller shaft when installing it with the plastic key? It looks like there is only one way to install the impeller on the shaft with that plastic key. The o-ring gets in the way so I put in down at the bottom of the shaft, slid the key into the impeller at the shaft indentation, then fit the o-ring in the bottom of the impeller. I wont install the lower unit until I find this out.<br />Thanks.<br /><br /> Joe
