skeeterFever
- Aug 30, 2009
- 29
well i dont know what this is,,,,,but see the little hole in the inside of the pump.........i cleaned it out now,,,,but it had about 1/16---1/8 piece of plastic sticking out........like it was part of the casted pump housing itself.....
i replaced impeller a few days ago- and after a few minutes had an over heat,,,,not to hott...but wasnt right....i did not see this {piece-defect or problem } prior to putting in the impeller...
i clened that big burr off,,,,not protruding now.....is this housing shot????
needless that protrusion destroyed the impeller somewhat: shoulda seen it the first time-but im green.... i cleaned and picked it out and sanded it with fine 600 grit, then 800 gritt....smooth now......prolly will order whole unit this time,,,,,,
anyone seen this or got clues to what happened..
1979 merc inline 6 115hp
the protruding piece coming from that hole actualy dug in and cutt the impeller to bits.....{the impeller didnt dig into that hole} that hole had pump housing plastic sticking out of it that dug into impeller}
