water pump change shift linkage
Rtauzin
I have a 145 Tohatsu, where do I disconnect the shift linkage to drop the lower unit.
steelespike
Re: water pump change shift linkage
You would be better off with this in the Tohatsu section.I only have info for the 90 it says to remove the shift rod coupler from the lower shift rod It appears to be held by a roll pin.Hopefully the 90 is similar to the 145.good luck
