having problems with the water coming out of the tell-tale, water does not come out with too much pressure. running hot on gauge when iding. change heat sensor, impeller and thermostat. any ideas?
took impeller apart again and same problem, do you think it might be the poppet valve? looks like i might have to take alot of things out to do that. [h=1][/h]
That motor will not pee at an idle or until the thermostats open. It will need to be around 1200 rpms before it starts coming out the peeholes as I think it has 2.
