I was wondering what the water pressure should be on my 2000 J130PLSS 130 Johnson.<br />At idle it stays around 5-10psi. At WOT 6,100rpm<br />it reads off the scale. My Pressure guage only goes to 30psi and it looks as if it reads some where around 60psi on the guage. And i just noticed after putting it in the water for the first time this year my pressure guage makes a hissing noise. Everything runs fine, i was just wondering if there is a pressure regulator that was stuck or something. The pressure guage is tied into the block where the owners manual tells you to tie into it.<br />--Hop
