Water pressure relief valve
elwilliams13
Does the 91 evinrude 225 have a water pressure relief valve? If so where is it located?
R.Johnson
Re: Water pressure relief valve
The relief valve is incorparated in the thremostat housing. At idle the coolant flows through the thermostat that is held on it's seat with a spring. At wide open throttle, or before water pressure from the pump forces the spring back, allowing full water flow.
