mercurymang
Master Chief Petty Officer
- Jul 14, 2012
- 853
I have a 75 merc 650 (3cyl) and have recently replaced the baffle, outer cover, thermostat, impeller, etc. The tell tale comes off of the base before entering the block so if there as a restriction in the block, you would not know it by the tell-tale. I have been advised that on this motor they can build up steam pockets in the upper cylinder jacket and cause overheating. One solution is to plug the factory tell-tale outlet and drill a new one in the block above the top cylinder. This would allow any trapped air/steam to escape and the water to get all the way to the top of the block.
Before I go drilling holes in my block, I thought I would throw this out for comments and see what opionions some of you may have.
Additionally, I would like to remove the factory plug in the block and install either a temp guage or a pressure guage.
At any rate, it seems wierd to me that merc would design a block where air or steam would get trapped at the top of the block causing water to not flow there.
I would appreciate you thoughts on this matter.
