Re: Water Pressure Gauge
I'm not going to be much help with this, but I'm looking at a boat with a 200 Ocean Pro that has a water pressure guage. It's installed inline on a crossover hose, not tapped into the block. I thought it was strange. The owner says his mechanic checked it out and couldn't find a tap into the block to use. The gauge works fine, but the pressure reading is lower than what you'd expect. Let me know if you find a factory tap and I'll do the same if I find one.
