looper power
- Jan 23, 2005
- 65
my previous motor, 1985-140 looper had the water recirc valve installed. from the bottom of the block, starboard,there was a fitting that went from the block to the recirculation valve. thats where it had the tee for the pressure gauge. the 1985-140 motor I'm putting on now has the updated thermostat housings so it has no recirc valve. the fitting out of the bottom of the block is there but capped. where do I put the pressure gauge fitting? directly to that or is there another fitting? thanks
