Re: Water pressure at WOT on 150 mariner??
If you are having 25psi at 2500-3000 rpms you most likely do have a poppet valve problem... Sticking shut or clogged up with debri....<br /><br />You should see the poppet open around 15-18 psi at around 2500-3000 rpms... <br /><br />However, your wot pressures will still increase above that range even after the poppet opens.. 20-25psi is normal... At around 5600-6000 rpms... Maybe a little lower is also normal because of your hp, which is mainly due to your gear ratio in the lower unit... 150hp pressures will be lower vs. a 175hp and 200hp....<br /><br />But before you carve that in stone, what year is your motor?
