Mine is 18 psi at WOT, with a weak stream at telltale . At idol it's 5psi with a great stream.I have replaced both water pump and poppet valve. Do these #'s look right?.Thanks
What year is the motor....<br /><br />I see slightly higher numbers on my 175...<br /><br />5psi at idle with stats open...<br />10-12 psi at idle with stats closed...<br /><br />20-23 psi at WOT...With a strong stream...
