Re: water pickup screens
Yessir, screens are internal....OMC p/n 0321123 for the original, maybe should have mentioned a) it's 1994 150GLERA model 20" shaft b) not original gearcase as it's been mod'ed by grinding top of shaft at splines as well as the area below the splines...i'm guessing it may be off a 175-200 hp model. Looks like one may need to remove the impeller base plate to get access to the screens...
believe there is also a philips screw that holds the screen in place on the starboard side.....I'll figure it out this winter as that's when I may pull the gearcase again and do the pump.....I had a previous post regarding a "mystery" crack in this gearcase:
http://forums.iboats.com/showthread.php?t=276234
Impeller looked pretty tip top upon last inspection...
For now I just keep an eye on it and a sparkplug socket handy so I can clean out the tell-tale if I get up in the pluff mud.
PS: Dhadley, i finally resolved a low/mid sputter cough issue by very carefully going thru the carbs (again) and those pesky teeny weeny low/mid orifices in the intake/throttle body manifold....motor's running fine now....on my 18ft Mckee I liken it to a "Pit Bull on a leash"
Been fun and educational diving into a larger 6-cyl outboard as I didn't have much experience with larger engines...now I could rebuild and dial-in those carbs w/ a 3/8th socket, philips and leave the manual on the shelf...
for those interested in a first time monster boat refurb, see my site at:
http://www.deviljohn.net/
Thanks
JD
