Hi All,
I have a 95 Lund Tyee 1850, with a 4.3 Volvo GS and DP-C drive and closed cooling system. So I've owned this boat on what will now be the 3rd season, so I'm still learning things about the Volvo set up and seeing things I've never seen before.
Last year I got the boat out, put the hose on it and it fired right up. This year I put the hose on it, (water on wide open) fired it up and after about a minute I smelled something hot so I shut her down. The belt driven raw water pump was so hot I couldn't touch it! Ok, so I likely just smoked the water pump impeller.
When I got out of the boat to make sure the muffs were still on the drive, they were, I noticed a stream of water coming out of a hole maybe about 1/2" diameter. This hole is in the front of the gear case, below the "cone". Maybe on the same plain as the gear oil drain plug.
Questions:
1. is this hole I'm referring to a drain hole, or some type of low water pick up? Is it supposed to be there?
2. The raw water pump is a Sherwood brand. I'm obviously going to replace the impeller, but there is a thing called the impeller cam. It has some grooving on it, are these grooves "normal" or should the cam be flat accross with no grooves. Having never seen one before I would call it accessive, but then I don't know. Should I replace the impeller cam?
Thanks in advance for your replys.
Questions:
