fowl intent
- Feb 17, 2003
- 39
I have a Tracker 16' (1987) v-hull I use for duck hunting and fishing. I mounted a 2000 Johnson 35 hp long shaft, tiller steer approx. a year ago, and I have noticed that at high speed water will sometimes come in over the transom. The water seems to be deflecting off of the outboard shaft with enough force to climb up and over the transom. It is not a major problem, as I have a manual bilge pump, but it sure is a pain. The motor seems to be mounted at the proper height, and I have played around with the tilt angle, but nothing seems to remedy this. I have thought about making an aluminum plate to attach to the transom which would have a bend or flare to throw the water off the transom. Any better ideas?
