water not spitting out
waterdog65
I have a 1973 or 1974 evinrude 65 horse, and it runs fine and runs cool but there is no water spitting out of the motor when running. Its been like this since i baught the boat and the guy before me said the same. should i be concerned?
jee70611
Re: water not spitting out
I would try to see if the outlet is clogged. I think on those motors the two holes on the back of the leg should have water "spitting" out of them. I'm not sure though, but you'll get a better response in the Evinrude/Johnson Outboard forum ;) . Good Luck!!<br /><br />James
walleyehed
The water flow from the 2 holes on the mid-section flow, and stop in relation to the thermostats working.....They are not a tell-tail.
JB
Moving to JohnnyRude Troubles.
