Re: Water not pumping Merc 50 HP 1987
Thermostat is located under port side manifold cover, if it's the engine I am thinking of there will be 18 bolts keeping it on, gently undo these, any that are a problem may need a little heat (DO NOT FORCE)..when all the bolts are out try to split the outer water jacket gasket leaving the inner exhaust gasket intact, dont worry if both gaskets split it's just gonna cost you more. And there it is that round thing that just fell out.<br /><br />When re-assembling use new gaskets, make sure everything is clean, put the three gaskets on dry, (third gasket being the L shaped gasket between outer cover and baffle plate), a little Loctite on the threads and torque outer 16 bolts to 150inch lb. Please find out torque settings for the two middle bolts as I cannot remember and definately do not overtighten..<br /><br />Best of luck Keith B...
