Water not getting through exhaust manifold
jlormis
I have a 1993 5.8l and I noticed that the port side exhaust manifold and riser was getting (what I felt) too hot. I took the hose off of the thermostat housing and stuck the garden hose on it, sure enough, No water is getting through that side. I am guessing that corrosion and rust are blocking the water passage and I was wondering if there is a way I can clean this out effectively or if I need to buy a new exhaust manifold.
rbezdon
Re: Water not getting through exhaust manifold
I'd get a new one. Your boat is a 93 (12 years old and from what I read the useful life for a minifold is only a couple of years anyway. In fact, I'd replace both sides and the risers.
Originally posted by j. allen:<br /> or if I need to buy a new exhaust manifold.
Ayuh,...........<br /><br />That's what needs Doing,............ ;) <br /><br />Both sides,.. Of Course.........
jlormis
I thought so, but I was just trying to see if I ould be cheap. I replaced the otherside this spring when I noticed a small crack starting to develop - thanks for the info - <br /><br />Also, on a side note, I have only had the boat for a bout a year, and I hooked it up to the fake lake recently and couldn't get good water flow through the engine, like zero - should I be able to without the impeller submerged - or is this just the "way it is" I thought if this was not normal I would go ahead and replace the impeller while I was at it.
Ayuh,........<br /><br />That's Not Normal........
