This might be a silly question but, can I use water muffs on a 71' evinrude 25hp? If so where would I attach them,it is not obvious to me where the intake hole or holes are?? Thanks
no you can not. water pick up is part of the piece above the prop where the exhaust comes out. need a barrel or large garbage can. motor leg needs to be submerged 1/2 way up, water pump is not self priming. keep the water hose on when running.
