rhartSilverdale
- Aug 29, 2003
- 15
Hello again,<br /><br />I was afraid that my post got buried...so here's it is once again. Sorry if I'm being a squeeky wheel.<br /><br />I have a 1985 OMC 140 (3.0L inline 4, non-cobra) I/O in a 19' Bayliner Cuddy. The boat and motor have been sitting idle for about the last 4 years. It has altogether less than 150 hours since new (I'm the original owner). It has a raw water cooling system. When I finally brought it out of mothball, I'd tuned it up, and she runs like a top, except now there's a steady stream of water that runs out of the little hole at the bottom the bell housing cover plate into the bilge. It's not shooting out of there, but it's a pretty good trickle. There's no sign of water in the crank case oil, nor in the intermediate housing, or the gear cases. Also, I've checked to see if there were any water leaks from the exhaust manifold, hoses, freeze plugs, drain plugs, or the manifold rubber coupling to the bell housing/intermediate housing -there were none. Everything above the bottom half of the bell housing appears to be dry. Is there a freeze plug at the end of the block hidden under the bell housing? If anyone has any ideas or experience with this sort thing, I will appreciated it greatly. It would be a real pain to have to pull the engine, especially if it turns out to be a simple fix.<br /><br />Many thanks.
