I just replaced the water pump impellor on my '85 3.5 hp merc and it seems to be pumping water fine however I am noticing that water now leaks out of the seam where the upper and lower unit meet. I do not recall this happening before I started the project. There did not appear to be any gasket or gasket sealer on the surface where the two meet. The water tube is seems to be aligned correctly. Any suggestions?
