The iboats forum moderators are excited to announce that at this time it appears the iboats forums posting pictures function is working once again. Though we cannot promise for how long, we're hoping for indefinitely.
Any chance you can supply a picture? I am a bit confused by this.<br /><br />Are you refering to the external tank feeding the small onboard tank on the engine?<br /><br />TMD
Ok...I looked in the parts manual. I see the hose you are talking about. Check your resovior for water. The water should be on the bottom of the tank...I will be separate from the oil.<br /><br />TMD
The water is coming from the high speed daiphfram on the side of the motor. It is part of the cooling sy.tem and water squirts out. Do you see it in the manual? Thanks, Dale
