I just had new ujoints installed on my 1990 Mach 1 that has a 4.3 Mercruiser. When in the water, I run the bilge about every 45 minutes and it runs for about a minute. The last time I brought my boat on the trailer, I left the plug and bilge water in the boat and backed my trailer on a steep incline. I noticed that water was leaking out of the boat at the bottom of the outdrive where it meets the transom.<br /><br />1. Can this cause damage to motor?<br />2. Should I deal with the leak a couple more times and get it fixed when the season is over?<br />3. Can I use marine sealant to seal outdrive housing to transom to stop water from getting in?<br /><br />Yes, I am new to boating. Thanks again.
