water leakage
snowmonster9
i have 1 1996 celebrity 19ft. bowrider w/ a 5.7 merc i/o motor. i took it out last night for the first time this season and when i got up on plane i noticed tha water was pouring out of the steering bracket under the console. any ideas , dave
Re: water leakage
Ayuh,...........
It sounds like the Pitot Tube has come disconnected from the Speedometer......
gcboat
Re: water leakage
Look under your dash by your speedometer. There will be a small hose - approx. 1/8" in diameter - this is your water pick up. It comes from the back of the boat, connected to a plastic fitting that looks like a skinny sharks fin. Water is pushed through that tube to your speedo which gives you a speed average. Anyhow, if that tube came off it will just push water onto the floor, etc. Replace it and all should stay dry. Try and secure it with a small tie wrap. :D
Bob_VT
Re: water leakage
The pitot tube is what controls most speedometers. It is a small plastic tube that runs all the way to the back of the boat and is normally located at the bottom of the boat. Water pressure is what drives the speedometer. Your's is either cracked or no longer connected.
You can either trace the problem under the dash or be prepared to abandon ship in the event of sinking!!! :eek:
Silvertip
Re: water leakage
Actually, water is not forced up to the speedometer head. Water pressure compresses the air in the tube which operates the speedometer head. Don't just reconnect the tube. Disconnect it at the back of the boat, blow out the water, then reconnect everything. Replace the tube if its damaged.
