Hi there
I have following problem with my Honda BF90 2003 :
A transition piece from the water pump to the engine, with a metal pipe that connects via a rubber hose to the water control beam. The metal pipe is broken. I dont find it as a seperate sparepart in available manuals.
On attached photos you will find the "metal pipe".
Is it possible to buy this "metal pipe" as a seperate unit and replace it ? Or is it an integrated part of the case mount ?
Thank you so much in advance !
Danethor
