Re: water jacket gasket question
If the spark plugs screw into it, it is essentially the head, no matter what the book calls it. It usually is a black cardboard type gasket, and it has metal rings where the cylinders holes are, and sometimes other metal around the edge. Do not use any sealer on this gasket. It compresses when you torque it down, and be sure to follow the torqueing sequence which should be in you book. Also, this gasket is a one time use gasket b/c it compresses. Hope this helps.
