I just bought a 10hp Johnson, model QD-16 ser.1270223, a 55 model. I ran it in a bucket and did not have water coming out the pee hole. i removed the lower unit and the impeller was new (had a plastic housing and very pliable vanes). i put the lower unit back on, but haven't tried it yet. i have read several posts here and some say that the water doesn't come out the pee hole on some motors, but out the exhaust hole on the bottom of the motor. there was a copper tube that ran into a grommet on the upper unit and i put the copper tube back in it. i also changed the lower unit oil while i was there. there was equal parts water and oil that came out. i also noted that some posts say there is an o ring that goes under the impeller. there wasn't one on this one. can anyone tell me if there is supposed to be a stream coming from the pee hole, and is there supposed to be an o ring on the bottom of the impeller? also, it doesn't seem to want to idle. i can get it run for only about a minute before it wants to die. that should be long enough for water to come out right?
