marco_0521
- May 14, 2008
- 19
My Mercruiser alpha gen II 4.3 leaks water from the water inlet. Originally, I thought it was just the clamp, so I tightened it and the leak continued.
I took the water hose from the engine out and verified that the leak is coming from around the water inlet. Also, the water inlet seems very loose. The water inlet has two screws that I took out. I expected to find a gasket or something, but I didn't. There is a gasket that I can see but is on the oposite end of the water tube (the end that conects a hose with the gimbal bearing).
For disclosure, we did replace the water hose, but the old one didn't have a gasket nor we got a new one with the new hose kit.
So my questions are
1. Is it just a matter of installing the new gasket on the engine side, or do I need to do anything about the gasket on the transom side. In other words, how do I fix it.
2. Can I get the gasket on a marine shop or do I have to get it from the dealer. Also, can I used something else like a gasket-forming product at an automotive store?
Thanks,
So my questions are
Thanks,
