vissertrades
- Aug 16, 2003
- 79
Just got a newer motor installed and mechanic noted some water when he drilled four new holes. Boat is a '84 Smokercraft aluminum. Transom seeems solid now, talked with smokercraft and they recommended a product called "get rot" that can be sprayed into the transom. Any idea where I can get this stuff? Any other advice? Mechanic suggested spraying into the old mounting holes as he thought that was the leaking source.
