Water in the oil
patrick garrett
My bilge pump quit at my camp. Water was over starter and just touching the bottom of the alternator. After pumping the boat out and letting the engine dry out for a day the boat started fine and has run great for several days. I checked the oil and it was cream. I drained it and changed the oil filter and the oil still has water in it. Would there be left over water in the engine., or do I have other problems? Boat runs fine
Re: Water in the oil
Ayuh,... At this point it's Either, Or....
Is the oil level Rising when you run it,..??
If Not,...
Change it again,+ then Try it again...
If the oil level IS rising,... You've probably got a Cracked Block...
