mark_lybarger
- Jul 16, 2005
- 8
i haven't had very good luck with this boat so far, and it's our first boat. perhaps next time, we'll break down and buy a new one or at least we have some better knowledge to look for next time.. regardless, our boat won't start. the mechanic says there's water in the cylinder and water doesn't compress, so the boat doesn't turn over. <br /><br />this is 2 days on the water after the same mechanic/shop replaced the flywheel/starter because it wasn't starting. i don't know why they wouldn't have looked for water originally, but that's beside the point. they tell me now that they can't determine where the water is coming from. they said they don't see water in the cylinders like this. they said the oil isn't milky, but it's in more than one cylinder at least on one side. i don't think they removed the plugs on the other side to see.<br /><br />the possibilities they've mentioned to me are: 1, head gasket. 2. cracked head, 3. exhaust manifold, and 4. cracked block. they said they placed a call into mercruiser for some better hints i suppose. the boat is a 94 genesis, w/ a 4.3 liter I/O mercruiser motor. the previous owner claims to have had it regularly serviced and winterized each year.<br /><br />i'd certainly appreciate any comments/feedback from the good folks here on the iboats forums.<br /><br />thanks!<br />~mark
