water in the bottom cylinder
87lundtyee
I have an old evenrude 10 horse and i got it running but when i took out the spark plugs the next day water drained out of the bottome cylinder. how did it get there? I was thinking head gasket but i just wanted some feedback.
R.Johnson
Re: water in the bottom cylinder
It can come from the head gasket, or the exhaust cover gasket
R.Johnson
pinedaddy
If the motor was taken off and laid down wouldn't it be possible for some water to just run up in the exhaust port? I've had this happen with my old johnson 10 which is the same motor I believe.
OBJ
If the engine is drained you should not get any water back from the exhaust.
