I drained the oil today and found there was some water in it. When I pulled the plug about a teaspoon of straight water came out, and the oil was a grayish color. Ran a compression check: 180, 180, 170, and 180. I usually keep the boat under a shed, but I left it outside for several months during the summer. Is there any way rain water or moisture could get in the crankcase with the motor tilted up? I went ahead and changed the oil and will run it some and see what happens. I hope it is not the head gasket due to water pump failure. Thanks for any input. Jdman
