I just traded for a boat and there was well over a gallon of water in the crank case.. The guy I got it from said he has had everything pressure tested (I don't know how much I believe him...) and block and head are sealed with no water leaks. He said the water is from when he changed the exhaust/intake gasket. Is that possible on a mercruiser 165hp 250cid L6? I've seen it a lot in v8 engines but never heard of it in an inline.. He had never used the drain plug and says that's why water is still there. (he used a pump thru the dipstick..) I haven't done anything but pull the plug and drain it out.
-1974 aristocraft nineteen
-Mercruiser 165hp
-Mercruiser 165hp
