water in lower unit???
manny-c
not sure if this means there is water in the lower unit or not, I didn't see water, but the oil is milky looking, but no water??
gto
Re: water in lower unit???
that be water or salt
Rex
For a $1.00 i would but lube in for about<br />2 to 3 times before I would decide on anything <br />yet.<br />Rex
Trent
Milky = Water<br /><br />Change as stated above and make sure you replace the gaskets on the vent and fill plug. Run and re-check in a few hours. If you still have milky oil its time for pressure and vacuum check to the lower unit.
Rex
You are talking about 200.00 to 300.00 for the<br />work. Just call around and ask.<br />REX
