water in lower unit
achris
More fish than mountain goat
Re: water in lower unit
Photos are too small to make out detail... What are we supposed to be looking for? What engine? Hp and serial number please...
C..........
gump1969
the pics are clickable thumbnails, and the gasket is broken on the water port side.
the motor is a 75 hp and ser G100614
ENSIGN
The gasket more than likley tore when you removed the housing.Iwould clean everything and reassemble using NEW SEALS and GASKETS.Pressure test the drive before you reinstall it.I've seen alot worse.
achris
That looks like damage from being overtightened.
C...........
gump1969
The gasket was like that before I took the plate off. As soon as I took the pump housing and pump plate off I could see it.
