BLU LUNCH
- Aug 8, 2003
- 1,316
I got home from work today and notice a little gear lube had run down from the top vent in the lower unit, so I drained the lower unit it was tilted up when I opened the lower fill screw as my son lower the engine i held the drain pan so I won't drip on the new driveway and I don't know if the water drained fron the prop but I got about 3 oz of crsystal clear water then what appeared to be normal looking gear lube it didn't look milky at all but the water baffled me. I got over 20 oz of fluid out and put it in a clear contaner to see if it would separte and it did not. What I found was the top seal on the screw was nearly gone it came out in pieces and the bottom was the same.....any clues? 1983 150HP Black Max
