Re: Water in lower unit...
My advise is to pressure test the lower unit before you decide to do the whole seal thing. Take the lower unit (LU) off. While it's drained (no oil), figure out a way to pressurize it. I've done it with a rubber stopper that I drilled a small hole through, slipped a piece of tubing through the hole and siliconed in place. Then used a syringe to pump air into the LU. I had T'd a pressure gauge on the line with the syringe (and a valve, so I could close off the LU, refill the syringe and give it another push of air). 10 psi is what shops will test with. Lay the LU in a kiddie pool (or something), and see where the bubbles come from. Mine wouldn't hold any pressure at all, and when I gave it a syringe of air, I got a nice push of bubbles from under the water pump. I replaced the pump base (new seals around driveshaft), and voila. I didn't need to mess with the other seals at all. I pressure tested it again after doing the water pump, and it held 10 PSI for hours, no problem. I used it the rest of last season, and the oil was perfect when I changed it in the fall.<br /><br />So the moral is, I'm really glad I didn't take all the LU apart because of a bad water pump seal! BTW, mine is a 150 HP V6, but that doesn't matter.<br /><br />good luck.<br /><br />Brent
