Re: Water in lower unit
Water in your gear oil can be very serious.Go to your local dealer and get the gearcase filler pump that screws into the plugs.Use the end of that hose attached to a mightyvac and go to it. That will tell you where your leak is .After that initial leak is fixed pump her up again and she should hold about 10 psi pressure or vaccume with shafts moving.
