Recently noticed small crack in lower unit where gear oil reservoir is. Sanded down crack and repaired with JB Weld cold weld. No more leaks there, however I am taking in water in the oil reservoir as the oil is "milky" and is coming out of the overflow hole in side of motor when running (connected to water hose). I noticed that my water pump is not sealed well as water is leaking from 1 of four screws on water pump housing. Will get o-ring to hopefully seal. As for the other seals, how many are there and where are they located? How do I replace? Any detailed instructions are greatly appreciated in advance!! dgrimme@peoplepc.com
