Hey Guys,<br /><br />I was starting to winterize my boat and while draining the lower end oil I notice it has some water in it. I drained it all and refilled it with new oil. The question is Im in Canada and it will most certainly get below zero here so if there is still water in there it will freeze. With that said should I have it serviced now to fix the problem and make sure all the water is out or would you think since I changed the oil all the water is out.<br /><br />Basically can I wait until the new year to service the seals and tear it apart or should it be done now before it gets cold?
