Had lower unit off to repair(weld) a thumb-sized chip in the upper "fin". Put new gasket kit in the water pump and re-assembled unit. Ran it on the muffs for a few minutes and checked to make sure it shifted OK. This is not my boat so I'm not sure how it should look, but water was coming out of the pee-hole but also out of several other holes & slots in the lower unit. Is this normal? Bottom line is, there is also water in the gear oil. The unit was not disassembled except for the water pump and the plastic seal that goes around the shift rod. Any ideas about how the water is getting in the oil?
