MY Drive Oil
MY Drive Oil
Well good news and bad news. I did what you said and drained the oil, I have not changed it because I am unsure of what oil I need to buy. So lets start off with the good news and move to the bad. The intermediate part of the drive was perfect NO WATER at all. The oil here was a like dark blue in color, and flowed nicely no water. Then the lower unit, I think it is ok as well, no milky oil or clear water. It was of a caramel color and also flowed nicely. It was not clear but I think it is just because this oil is of such high viscosity, Hopefully I am correct on this, I am not 100% sure of no water in this oil, but if there was it was not as noticeable as the upper. So I kept the lower oil in a clear bottle, I am going to let it settle for a few days, if water is in it I should be able to tell. Is a caramel color good or bad, as an all three oils were of a different color?
Then the bad news the upper part of the drive, the oil/ water, was very thick kind of like a grease and would change its viscosity back and forth quickly to being thin like water. It was a grayish white in color, definitely water as I even seen clear water drops in the pan as well as the oil water mixture.
Where should I go from here? I have pretty much flushed all of the water out of the upper with brand new cheap motor oil. How is this water entering the drive and how hard is it to fix, or is the boat headed to the scrap yard?
Here are some pictures of the oil. 1 of the lower unit and two of the upper.
